I don’t know if something has happened to my Lime or if there is a problem with my software or some other persistent settings. I used to get the expected result, but I’ve updated firmware and software since then. Here’s the version numbers
It used to look like the output in URL above. I don’t know if it has changed due to software or some other settings or if my Lime is broken somehow. Did any others experience anything similar?
LimeUtil --timing
Connected to [LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060A0259201F]
Creating instance of LMS7002M:
Timing basic operations:
>>> SPI write register: 0.023753 us
>>> SPI read register: 142.735 us
>>> TSP NCO setting: 1034.36 us
>>> RFE gain setting: 0.470757 us
>>> TRF gain setting: 0.905598 us
Timing tuning operations:
>>> CGEN PLL tuning: 9.44886 ms
>>> RF PLL tuning: 13.7703 ms
>>> TBB filter tuning: 175.065 ms
>>> RBB filter tuning: 300.217 ms
MCU error code(5): Loopback signal weak: not connected/insufficient gain?
>>> TX corrections: 168.552 ms
>>> RX corrections: 199.493 ms
Done timing!
Is it possible to run any of the BIST tests or other test software to check the Lime?
I tested my Lime on my wife’s Windows PC and everything seem to be ok with the hardware. I was asked to downgrade. So I assume this might be a software related problem. On Windows I get this version number:
I’ve had similar issues with new-ish Limesuite builds on OSX. I noticed that “Module=STREAM” is now changed to “Module=FX3”. Andrew suggested that this may just be a semantics issue referring to the name of the FGPA, but the problems we’ve experienced seemed to have occurred after this change. I also went back to an earlier version of LimeSuite / drivers and these errors are not present.
Thank you for your reply as I didn’t notice the difference in the module name.
I would like to go back to a stable version too. But which version is stable?
How can I find out the version of the released Windows build? It does not seem to output the git sha1 (unlike the Linux version) and there does not seem to be a tag in the git repository which corresponds to the release.
Also the stable branch results in the fft output above above.
I’m just chiming in here to say that I’m seeing the exact same behavior shown in your screenshot with a new LimeSDR USB running under Windows 10 and PothosSDR-2018.03.12-vc14-x64.exe. I noticed a newer release was available as PothosSDR-2018.03.31-vc14-x64.exe and I went through the same process, which results in a new, but also unexpected (and I suspect undesirable) FFT graph:
Followup - I just downloaded and installed PothosSDR-2018.04.08-vc14-x64.exe released yesterday and the quick test results with this new version match nicely with the example shown in the guide:
