Just starting out with LimeSDR and ecosystem. Did the USB loopback test, upgraded the gateware firmware to 2.20, etc.
Tried the Pothos Flow - Simple FM Demod, doesn’t work.
Started through the LimeSDR tutorial (https://myriadrf.org/news/limesdr-made-simple-part-4-pothos-beyond/), I can get static, but the “Insert Graph Widget” is disabled, grayed out.
Pothos v0.7.0-PothosSDR-2019.03.24-vc14-x64
I have the Python pythonsupport3.dll failed safe load problem, added it to the system path, still have that problem. Are the graph widgets dependent upon Python?
