Hi Guys,
Just got PothosSDR up to run and I have Python installed (2.7.13 64 bit) and come up with an error
that it is a Python problem along with a gateware problem. I was following the Pothos SDR environment tutorial
to try and get this setup correctly. Exactly which python version is used and how do you upgrade gateware?
Thanks!
Paul
[21:34:31.454010] PothosGui.MainWindow: Welcome to Pothos v0.5.1-PothosSDR-2017.08.13-vc14-x64
[21:34:31.594638] PothosGui.MainWindow: Initialization complete
[21:36:07.956000] Pothos.PluginLoader.load: Plugin Module Error: Pothos::PluginModule(C:\Program Files\PothosSDR\lib\Pothos\modules0.5\proxy\environment\PythonSupport.dll): failed safe load
[21:36:08.013000] : Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.002.000-0-gbd6e21dc
[21:37:15.571000] SoapySDR: Make connection: ‘USB 3.0 (LimeSDR-USB) [USB] 9061C02D12F13’
[21:37:15.587000] SoapySDR ⇒
Gateware version mismatch!
Expected gateware version 2, revision 8
But found version 2, revision 6
[21:37:15.759000] SoapySDR: Estimated reference clock 30.7196 MHz
[21:37:15.759000] SoapySDR: Selected reference clock 30.720 MHz
[21:37:15.759000] SoapySDR: Device name: LimeSDR-USB
[21:37:15.759000] SoapySDR: Reference: 30.72 MHz
[21:37:15.759000] SoapySDR: Init LMS7002M(0)
[21:37:15.759000] SoapySDR: LMS7002M cache C:\Users\Paul’s-i7-Torbo/.limesuite/LMS7002M_cache_values.db
[21:37:15.759000] SoapySDR: Ver=7, Rev=1, Mask=1
[21:37:15.790000] SoapySDR: LMS7002M calibration values caching Enable
[21:37:16.118000] SoapySDR: Rx Filter calibrated from cache
[21:37:16.118000] SoapySDR: Tx Filter calibrated from cache
[21:37:16.149000] SoapySDR: Rx Filter calibrated from cache
[21:37:16.149000] SoapySDR: Tx Filter calibrated from cache
[21:40:16.337000] : Proxy server: No active connections - terminating
[21:40:35.221000] Pothos.PluginLoader.load: Plugin Module Error: Pothos::PluginModule(C:\Program Files\PothosSDR\lib\Pothos\modules0.5\proxy\environment\PythonSupport.dll): failed safe load
[21:40:35.299000] : Win32; Microsoft Visual C++ version 14.0; Boost_106300; UHD_003.010.002.000-0-gbd6e21dc
[21:40:53.730000] SoapySDR: Make connection: ‘USB 3.0 (LimeSDR-USB) [USB] 9061C02D12F13’
[21:40:53.754000] SoapySDR ⇒
[21:40:53.918000] SoapySDR: Estimated reference clock 30.7196 MHz
[21:40:53.918000] SoapySDR: Selected reference clock 30.720 MHz
[21:40:53.918000] SoapySDR: Device name: LimeSDR-USB
[21:40:53.918000] SoapySDR: Reference: 30.72 MHz
[21:40:53.918000] SoapySDR: Init LMS7002M(0)
[21:40:53.918000] SoapySDR: LMS7002M cache C:\Users\Paul’s-i7-Torbo/.limesuite/LMS7002M_cache_values.db
[21:40:53.918000] SoapySDR: Ver=7, Rev=1, Mask=1
[21:40:53.949000] SoapySDR: LMS7002M calibration values caching Enable
[21:40:54.261000] SoapySDR: Rx Filter calibrated from cache
[21:40:54.261000] SoapySDR: Tx Filter calibrated from cache
[21:40:54.293000] SoapySDR: Rx Filter calibrated from cache
[21:40:54.293000] SoapySDR: Tx Filter calibrated from cache
[21:40:54.590000] ::1: SetFrequency using cache values vco:0, csw:10
[21:41:44.846000] ::1: SetFrequency using cache values vco:0, csw:10
[21:41:45.583000] ::1: SetFrequency using cache values vco:0, csw:10
[21:41:46.142000] ::1: SetFrequency using cache values vco:0, csw:10
[21:41:56.846000] ::1: SetFrequency using cache values vco:1, csw:141
[21:44:06.781000] ::1: SetFrequency using cache values vco:0, csw:10
[21:44:09.907000] ::1: SetFrequency using cache values vco:1, csw:122
[21:45:52.174768] default: libpng warning: iCCP: known incorrect sRGB profile
[21:46:03.847342] default: libpng warning: iCCP: known incorrect sRGB profile
[21:46:43.408281] default: libpng warning: iCCP: known incorrect sRGB profile
[21:47:49.861652] default: libpng warning: iCCP: known incorrect sRGB profile
[21:47:52.862140] default: libpng warning: iCCP: known incorrect sRGB profile
[21:47:54.860491] default: libpng warning: iCCP: known incorrect sRGB profile
