Dear all,
this is mail is simply the consequences and conclusions as a result of more than 4 months working with a “LimeSDR mini” module, which basically can be sumarized as “I AM FED UP with Lime SDR”. And I want to explain why:
- GNUradio is poorly documented but if you put effort and determination looking at examples, reading FAQS … you can reach your goals. SO FAR SO GOOD.
- But LimeSRD docomentation about LimeSDR modules, (“mini”) in my case, is very poor, is incomplete, and waht is worse it is out of date inmost cases.
- You take the effort to install LimeSuite SDR you discover a powerfull tool with mani options and registers and if you look for documnetation is refers to older versions, so at the end you cannot run the examples, you cannot follow the procedure described. IT IS SIMPLY USELESS and A WASTE OF TIME
- When you try to calibrate the module, sometimes you can not calibrate RX, hardly TX. You get several error messages, and THERE IS NOT USEFUL INFORMATION in the web
- if you look MYRIAD threads I see people asking eh same questions I have but hadrly EVER they get srital clear effective answers.!!! LimeSDR i s a wate of time
I’ve said …!!
