I have a Lime Mini 2.4 bought last week from Crowd Supply.
Testing with Gnu Radio 3.10 (using the Soapy LineSDR source and sink) under Ubuntu 22.04 for Rx and Tx performance seems to indicate performance issues. On Rx, the Minimum Discernible Signal is -80 dBm. On Tx the maximum output is around -40 dBm.
LimeQuickTest shows some failed tests.
Any assistance on how to proceed would be welcome, please.
LimeQuickTest
->Start time: Mon Apr 7 22:40:36 2025
->LimeSuite version: 22.09.0-ge829d3ed
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1DA13CDBCB3B1C, HW=7, GW=2.6
Serial Number: 1DA13CDBCB3B1C
Chip temperature: 16 C
->REF clock test
Test results: 18294; 19876; 21394 - PASSED
Results : 6710965 (min); 6711005 (max) - FAILED
FAILED
->Clock Network Test FAILED
Operation failed: error code 5
->FPGA EEPROM Test FAILED
->LMS7002M Test PASSED
->Run Tests (TX_2 → LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-24.3 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 → LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-19.9 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 1.27 seconds
Thanks
Dave
