Im trying to run OpenBTS-UMTS by by using Soapy UHD driver… I have sucessfully run it with USRP B210, but i want to use LimeSDR.
I have this errors:
Nov 21 17:06:34 QUARKS2 sipauthserve: opening configuration table from path /etc/OpenBTS/sipauthserve.db
Nov 21 17:06:34 QUARKS2 OpenBTS-UMTS: opening configuration table from path /etc/OpenBTS/OpenBTS-UMTS.db
Nov 21 17:06:34 QUARKS2 sipauthserve: ALERT 12867:12867 2017-11-21T17:06:34.4 sipauthserve.cpp:328:main: sipauthserve (re)starting
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 OpenBTS-UMTS.cpp:166:main: OpenBTS-UMTS (re)starting, ver 1.0-master build date Nov 20 2017
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=64 chcode=2 which conflicts with reserved channel: sf=32 chcode=1
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:532:fecComputeCommon: fecComputeCommon(0,0) TB=1x256 coded=560
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:532:fecComputeCommon: fecComputeCommon(0,1) TB=2x256 coded=1120
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:468:fecComputeUlNdataj: trchx: 0 1 560 256
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 0, 256 150 143360
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 1, 256 300 143360
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 2, 256 600 143360
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:468:fecComputeUlNdataj: trchx: 0 1 1120 256
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 0, 256 150 286720
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 1, 256 300 286720
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 2, 256 600 286720
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:478:fecComputeUlNdataj: sfi: 3, 256 1200 286720
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:371:ulEquation1: ulEquation1[0,0]: ulSum=143360 Ndataj=600 Zij=600 Fi=1 Nij=560 deltaNij=40
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:371:ulEquation1: ulEquation1[0,1]: ulSum=286720 Ndataj=1200 Zij=1200 Fi=1 Nij=1120 deltaNij=80
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:532:fecComputeCommon: fecComputeCommon(0,0) TB=0x360 coded=0
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:532:fecComputeCommon: fecComputeCommon(0,1) TB=1x360 coded=760
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:405:dlEquation1: dlEquation1 TrCh 0 Ndataj=1080 Nistar=Nij=760 dlSum=194560 Zij=1080 deltaNij=320
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:713:fecComputeDlTrChSizes: fecComputeDlTrChSizes TrCh 0 Nistar=760 deltaNistar=320 deltaNimax=320 RFseg=1080
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:737:fecComputeDlTrChSizes: fecComputeDlTrChSizes(0,0) deltaNi=320 coded=0 deltaNTTIl=0 maxNTTIil=760
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSL1CC.cpp:737:fecComputeDlTrChSizes: fecComputeDlTrChSizes(0,1) deltaNi=320 coded=760 deltaNTTIl=320 maxNTTIil=760
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 ./UMTSL1CC.h:635:l1GetDlTrBkSz: getNumTrCh: 1
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 UMTSConfig.cpp:770:regenerate: regenerating system information messages
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=256 chcode=2 which conflicts with reserved channel: sf=128 chcode=1
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=64 chcode=3 which conflicts with reserved channel: sf=32 chcode=1
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=256 chcode=4 which conflicts with reserved channel: sf=128 chcode=2
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=256 chcode=0 which conflicts with reserved channel: sf=128 chcode=0
Nov 21 17:06:34 QUARKS2 openbts-umts: ALERT 139990016456576 17:06:34.4 UMTSPhCh.cpp:654:chConflict: Attempt to reserve channel: sf=256 chcode=1 which conflicts with reserved channel: sf=128 chcode=0
Nov 21 17:06:34 QUARKS2 openbts-umts: NOTICE 139990016456576 17:06:34.4 OpenBTS-UMTS.cpp:100:startTransceiver: starting transceiver ./transceiver 1
Nov 21 17:06:34 QUARKS2 transceiver: opening configuration table from path /etc/OpenBTS/OpenBTS-UMTS.db
Nov 21 17:06:34 QUARKS2 transceiver: configuration parameter UMTS.Radio.UHD.DeviceAddress has no defined value
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.4 Transceiver.cpp:244:driveControl: command is CMD POWEROFF
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.4 Transceiver.cpp:244:driveControl: command is CMD TXTUNE 2137600
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.4 Transceiver.cpp:244:driveControl: command is CMD RXTUNE 1947600
Nov 21 17:06:39 QUARKS2 openbts-umts: NOTICE 139989901444864 17:06:39.5 UMTSCommon.cpp:85:setFN: clock set FN: oldFN=507 newFN=580 diff=-73 BaseTime.sec=1511258799 .usec=500355 t=1511258799.50
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.5 Transceiver.cpp:244:driveControl: command is CMD SETRXGAIN 57
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.5 Transceiver.cpp:244:driveControl: command is CMD POWERON
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.5 Transceiver.cpp:111:start: Starting the transceiver
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.5 Transceiver.cpp:137:start: Transceiver running
Nov 21 17:06:39 QUARKS2 transceiver: NOTICE 140692957521664 17:06:39.5 Transceiver.cpp:244:driveControl: command is CMD SETPOWER 0
Nov 21 17:06:39 QUARKS2 openbts-umts: NOTICE 139989901444864 17:06:39.5 UMTSCommon.cpp:112:FN: TIME RAN BACKWARDS: prevFN=581 prev.sec=1511258799 usec=523084 currentFN=580 now.sec=1511258799 usec=523447 deltaSec=0 deltaUSec=362 elapsedUSec=362 elapsedFrames=0
Nov 21 17:06:39 QUARKS2 openbts-umts: NOTICE 139989901444864 17:06:39.5 UMTSCommon.cpp:117:FN: basetime.sec=1511258799 usec=523085
Nov 21 17:06:39 QUARKS2 openbts-umts: NOTICE 139989901444864 17:06:39.5 UMTSCommon.cpp:118:FN: prevdeltaSec=0 prevdeltaUSec=16377 prevelapsedUSec=16377 prevelapsedFrames=1
Nov 21 17:06:39 QUARKS2 transceiver: ALERT 140692817184512 17:06:39.5 UHDDevice.cpp:494:check_rx_md_err: UHD: Loss of monotonic time
Nov 21 17:06:39 QUARKS2 transceiver: ALERT 140692817184512 17:06:39.5 UHDDevice.cpp:495:check_rx_md_err: Current time: 0, Previous time: 89212
Nov 21 17:07:00 QUARKS2 transceiver: NOTICE 140692957310784 17:07:00.1 Transceiver.cpp:157:stop: Stopping the transceiver
Nov 21 17:07:00 QUARKS2 transceiver: NOTICE 140692957310784 17:07:00.2 Transceiver.cpp:177:stop: Transceiver stopped
Nov 21 17:07:00 QUARKS2 transceiver: ERR 140692957310784 17:07:00.2 UHDDevice.cpp:442:stop: Device not running
Full Log: https://www.dropbox.com/s/st7uow260laxrlj/OpenBTS-UMTS-SoapyUHD-LimeSDR-Test01.log?dl=0
