hi,
i have been following myriadrf limesdr specific guide for OAI and also looking at multiple solutions available in this forum. i am getting 2 issues
sudo -E ./run_spgw crashes with “ERROR in loading gtp kernel module” & " Initializing GTPv1-U ERROR"
i did perform the lowlevel kernel installation but it didnt fix this issue -
lte-softmodem.Rel14 just stays at “Entering ITTI signals handler” with limesdr acting as it isnt attached at all. (when i disconnected it same log appeared)
Lime is connectable via the suite, uhd_find_devices, and LimeUtils.
attached is the log
hannan@hannan:~/LTE/openairinterface5g$ sudo ./targets/bin/lte-softmodem.Rel14 -O targets/PROJECTS/GENERIC-LTE-EPC/CONF/enb.band7.tm1.25PRB.lmssdr.conf --rf-config-file targets/ARCH/LMSSDR/LimeSDR_above_1p8GHz_1v4.ini
[CONFIG] get parameters from libconfig targets/PROJECTS/GENERIC-LTE-EPC/CONF/enb.band7.tm1.25PRB.lmssdr.conf , debug flags: 0x00000000
[CONFIG] function config_libconfig_init returned 0
[CONFIG] config module libconfig loaded
[LIBCONFIG] config: 1/1 parameters successfully set, (1 to default value)
/dev/cpu_dma_latency set to 0us
[LIBCONFIG] log_config: 4/4 parameters successfully set, (4 to default value)
[LIBCONFIG] log_config: 38/38 parameters successfully set, (38 to default value)
log init done
Reading in command-line options
Getting ENBSParams
[LIBCONFIG] (root): 2/2 parameters successfully set, (0 to default value)
[LIBCONFIG] list RUs not found in config file targets/PROJECTS/GENERIC-LTE-EPC/CONF/enb.band7.tm1.25PRB.lmssdr.conf
Configuration: nb_rrc_inst 1, nb_L1_inst 1, nb_ru 0
[LIBCONFIG] loader: 2/2 parameters successfully set, (2 to default value)
[LIBCONFIG] loader.NB_IoT: 2/2 parameters successfully set, (1 to default value)
[LOADER] library libNB_IoT.so is not loaded: libNB_IoT.so: cannot open shared object file: No such file or directory
nb_nbiot_rrc_inst 0, nb_nbiot_L1_inst 0, nb_nbiot_macrlc_inst 0
[LIBCONFIG] TTracer: 4/4 parameters successfully set, (4 to default value)
configuring for RAU/RRU
CPU Freq is 3.408310
ITTI init
reported resolution = 1 ns
Before CC
Runtime table
NO deadline scheduler
[LIBCONFIG] eNBs.[0].NETWORK_INTERFACES: 3/3 parameters successfully set, (0 to default value)
ITTI tasks created
[LIBCONFIG] NETWORK_CONTROLLER: 6/6 parameters successfully set, (6 to default value)
Wait for the ITTI initialize message
XFORMS
[LIBCONFIG] L1s.[0]: 9/9 parameters successfully set, (7 to default value)
Initializing northbound interface for L1
[LIBCONFIG] MACRLCs.[0]: 21/21 parameters successfully set, (17 to default value)
sched mode = default 0 [default]
[LIBCONFIG] eNBs.[0]: 14/14 parameters successfully set, (8 to default value)
RRC 0: Southbound Transport local_mac
[LIBCONFIG] eNBs.[0].component_carriers.[0]: 107/107 parameters successfully set, (47 to default value)
phich.resource 0 (ONESIXTH), phich.duration 0 (NORMAL)
[LIBCONFIG] eNBs.[0].srb1_parameters: 6/6 parameters successfully set, (0 to default value)
[LIBCONFIG] eNBs.[0].mme_ip_address.[0]: 4/4 parameters successfully set, (0 to default value)
[LIBCONFIG] eNBs.[0].SCTP: 2/2 parameters successfully set, (0 to default value)
[LIBCONFIG] eNBs.[0].NETWORK_INTERFACES: 5/5 parameters successfully set, (0 to default value)
[LIBCONFIG] loader.coding: 2/2 parameters successfully set, (1 to default value)
[LOADER] library libcoding.so successfully loaded
NFAPI MODE:MONOLITHIC
START MAIN THREADS
RC.nb_L1_inst:1
Initializing eNB threads single_thread_flag:1 wait_for_sync:0
wait_eNBs()
Waiting for eNB L1 instances to all get configured … sleeping 50ms (nb_L1_inst 1)
RC.nb_L1_CC[0]:1
eNB L1 are configured
About to Init RU threads RC.nb_RU:0
wait RUs
ALL RUs READY!
RC.nb_RU:0
ALL RUs ready - init eNBs
Not NFAPI mode - call init_eNB_afterRU()
pcfich_reg : 0,12,25,37
ALL RUs ready - ALL eNBs ready
Sending sync to all threads
TYPE TO TERMINATE
Entering ITTI signals handler <---- just stays here with no response
below is the output for reference that limesdr is properly connected
hannan@hannan:~/LTE/openairinterface5g$ uhd_find_devices
[INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.11.0.git-776-gdca39145
– UHD Device 0
Device Address:
serial: 0009060B00472728
addr: 1d50:6108
driver: lime
label: LimeSDR-USB [USB 3.0] 9060B00472728
media: USB 3.0
module: FX3
type: soapy
LimeSuite Version 18.06
Ubuntu 16.04
MME & HSS are working with connected enbs = 0
