I’m trying openlte with soapyUHD after patching applying this patch patch_openlte.patch that i give on the last of topic for the resolving the compiling error. i got this error when i execute LTE_fdd_enodeb command (note that uhd_usrp_probe run correctly) :
– Make connection: ‘LimeSDR Mini [USB 3.0] 1D3AC779327FE0’
– Reference clock 40.00 MHz
– Device name: LimeSDR-Mini
– Reference: 40 MHz
– LMS7002M calibration values caching Disable
UHD Error:
Tx Calibration: MCU error 5 (Loopback signal weak: not connected/insufficient gain?)
– Rx calibration finished
UHD Warning:
popping from TX, samples popped 540/1020
UHD Warning:
any idea for solving this problem, please ?
patch_openlte.patch :
diff --git a/LTE_fdd_enodeb/src/LTE_fdd_enb_radio.cc b/LTE_fdd_enodeb/src/LTE_fdd_enb_radio.cc
index 7e03e08…9f1a011 100755
— a/LTE_fdd_enodeb/src/LTE_fdd_enb_radio.cc
+++ b/LTE_fdd_enodeb/src/LTE_fdd_enb_radio.cc
@@ -822,7 +822,7 @@ LTE_FDD_ENB_ERROR_ENUM LTE_fdd_enb_radio_bladerf::setup(uint32 idx,
buffer_size = 1024;
status = bladerf_sync_config(bladerf,
BLADERF_MODULE_TX,
BLADERF_TX_X1, BLADERF_FORMAT_SC16_Q11_META, BLADERF_NUM_BUFFERS, buffer_size,
@@ -842,7 +842,7 @@ LTE_FDD_ENB_ERROR_ENUM LTE_fdd_enb_radio_bladerf::setup(uint32 idx,
// Setup sync RX
BLADERF_MODULE_RX,
BLADERF_RX_X1, BLADERF_FORMAT_SC16_Q11_META, BLADERF_NUM_BUFFERS, buffer_size,
@@ -974,7 +974,7 @@ void LTE_fdd_enb_radio_bladerf::receive(LTE_FDD_ENB_RADIO_PARAMS_STRUCT *radio_p
if(radio_params->init_needed)
// Assume RX_timestamp and TX_timestamp difference is 0
bladerf_get_timestamp(bladerf, BLADERF_MODULE_RX, (uint64_t*)&rx_ts);
bladerf_get_timestamp(bladerf, BLADERF_RX, (uint64_t*)&rx_ts); next_tx_ts = rx_ts + radio_params->samp_rate; // 1 second to make sure everything is setup metadata_rx.flags = 0; metadata_rx.timestamp = next_tx_ts - (radio_params->N_samps_per_subfr*2); // Retard RX by 2 subframes
