I’m struggling with configuring Octave to use with LimeSuite. I’ve downloaded the latest Octave (5.2.0), installed communications, control, and signal packages. I’ve compiled LimeSuite (cmake output below). The problem comes when in Octave calling a routine like LimeInitialize can’t find the library. The library is located in /usr/local/lib. Octave is installed via snap so I haven’t been able to create a link or copy the library to someplace that Octave can find it. Any ideas? Thanks –
Octave output
LoadLimeSuite
LimeInitialize
error: /home/mike/github/LimeSuite/octave/LimeSuite.oct: failed to load: libLimeSuite.so.20.01-1: cannot open shared object file: No such file or directory
Cmake Output
– ## LimeSuite enabled features
- LimeSuiteHeaders, The lime suite headers
- LimeSuiteLibrary, The lime suite library
- ConnectionFX3, FX3 Connection support
- ConnectionFTDI, FTDI Connection support
- ConnectionXillybus, PCIE Xillybus Connection support
- LimeSuiteGUI, GUI Application for LimeSuite
- LimeSuiteExamples, LimeSuite library API examples
- LimeUtilCommand, Command line device discovery utility
- LimeQuickTest, LimeSDR-QuickTest Utility
- SoapySDRLMS7, SoapySDR bindings for LMS7
- LimeSuiteDesktop, LimeSuite freedesktop integration
- LimeSuiteOctave, LimeSuite Octave integration
– ## LimeSuite disabled features
- ConnectionEVB7COM, EVB+COM Connection support
- ConnectionSTREAM_UNITE, STREAM+UNITE Connection support
- ConnectionRemote, Remote Connection support for testing
- ConnectionSPI, Rasp Pi 3 SPI Connection support
- LimeSuiteDocAPI, LMS API Doxygen documentation
