Gentlemen,
I’m trying to run the quick_test with my LimeSDR on MacOS 10.12.
I successfully installed LimeSuite and managed to update the firmware to version 2.8.
However if I then run the quick test making all the test as described I only see the noise floor increasing by 5dB, and no signal appearing at all:
Do you know what could be wrong?
Also I tried to run SDR console v3 under paralells desktop, the device is recognised, but when I press play the SW hangs up…
Thanks for the help
Michel
