Hi All,
I am trying to run grgsm_scanner on LimeSDR USB but unable to get any results.
OS: Ubuntu 16.04
I know that the original grgsm_scanner is not made for LimeSDR so I have downloaded the app from
I have installed everything required and the app is finally working but not giving any output.
Posting the output here hoping someone has already done it before.
grgsm_scanner.py -b GSM900 -g 20 -s 2e6 -p 0 -v -d
linux; GNU C++ version 5.3.1 20151219; Boost_105800; UHD_003.009.002-0-unknown
LimeSuite Source (RX) info
Connecting to device
LimeSuite version: 19.04.0-gabf82140
gr-limesdr version: 2.1.4
Device list:
Nr.:0 device:LimeSDR-USB, media=USB 3.0, module=FX3, addr=1d50:6108, serial=0009060B00472728
INFO: device_handler::open_device(): no serial number. Using first device in the list.
Use “LimeUtil --find” in terminal to find prefered device serial.
Reference clock 30.72 MHz
Using device: LimeSDR-USB(0009060B00472728) GW: 2.21 FW: 4
INFO: device_handler::set_samp_rate(): set sampling rate: 2 MS/s.
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 925.9 MHz.
INFO: device_handler::set_analog_filter(): INFO: device_handler::set_gain(): set gain [RX] CH0: 20 dB.
RX LPF configured
INFO: device_handler::close_device(): Disconnected from device number 0.
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 927.9 MHz.
RX LPF configured
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 929.9 MHz.
RX LPF configured
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 931.9 MHz.
RX LPF configured
INFO: device_handler::set_rf_freq(): RF frequency set [RX]: 959.7 MHz.
RX LPF configured
Process finished with exit code 0
No error or warning is shown so I am not sure what is going wrong here.
Kindly help me out
