I’m getting this error message when trying to run
python measureVNA.py
I’m working on Windows 8.1 Pro and using Python 3.6.1 installed by Anaconda 4.4.0 (64-bit).
More details posted as issue on github here.
Thank you for your kind support,
mario
mario
You need Python 2.7 instead of 3.6. Just commented on and closed the issue.
Andrew
Thank you @andrewback for your kind reply.
Is a compatibility upgrade to Python 3.x planned in the short / medium term ?
…most of the scientific sw/packages i’m using is already there and the number of users of 3.x is constantly growing…
kind regards,
mario
Hi Mario,
Not as far as I am aware, but if someone would like to take this on it could make for an interesting project.
Hello @andrewback.
I solved that error adapting the import statements to python 3.6
I’ve been able to run the program but I faced a bigger issue with the pyusb package.
FYI, these are the changes needed: https://github.com/mariocannistra/pyLMS7002M
Ever since I don’t have much time to solve also the issue in pyusb, I will check if i can have python 2.7 on the same machine. This is the error message I got, probably some difference in pyusb for 3.6 vs 2.7 (more complete/mantained?):
Searching for LimeSDR... Traceback (most recent call last):
File "measureVNA.py", line 145, in <module>
limeSDR = LimeSDR()
File "C:\ProgramData\Anaconda3\lib\site-packages\pylms7002m-1.2.0-py3.6.egg\pyLMS7002M\LimeSDR.py", line 75, in __init__
File "C:\ProgramData\Anaconda3\lib\site-packages\pylms7002m-1.2.0-py3.6.egg\pyLMS7002M\LimeSDR.py", line 269, in getInfo
File "C:\ProgramData\Anaconda3\lib\site-packages\pylms7002m-1.2.0-py3.6.egg\pyLMS7002M\LimeSDR.py", line 242, in sendCommand
File "C:\ProgramData\Anaconda3\lib\site-packages\pylms7002m-1.2.0-py3.6.egg\pyLMS7002M\boardUSB.py", line 66, in controlTransfer
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\core.py", line 1025, in ctrl_transfer
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\core.py", line 102, in wrapper
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\core.py", line 120, in managed_open
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\backend\libusb1.py", line 786, in open_device
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\backend\libusb1.py", line 643, in __init__
File "C:\ProgramData\Anaconda3\lib\site-packages\pyusb-1.0.0-py3.6.egg\usb\backend\libusb1.py", line 593, in _check
NotImplementedError: Operation not supported or unimplemented on this platform
