Hello all,
I’m having an issue with my LimeSDR and was hoping someone here might share some insight. I’ve plugged the Lime into each of the USB ports on a dev board I’m using. It’s got Debian 9 on it, all the LimeUtil drivers, libusb-1.0-0-dev, I’ve run the udev-rules install shell script from the LimeSuite folder, etc…
The “lsusb” command shows that the device is there, it comes up as “OpenMoko, Inc”. On the Lime itself, one of the LEDs appears a solid green, while the other 3 flash very quickly either red or green, depending on which side they’re on, which I’ve looked for online, but it appears the documentation doesn’t specify this phenomenon. Still LimeUtil --find will return nothing.
If anyone can shed some light on this, it would be greatly appreciated.
Thank you!
