Hi everyone,
For my project I have to run enb on USRP b210 and UE on LimeSDR board. I can successfully run enb with following command in TDD mode on USRP b210:
sudo -E ./lte-softmodem -O …/…/…/ci-scripts/conf_files/enb.band40.tm1.25PRB.fairScheduler.usrpb210.conf -d --nokrnmod 0 --noS1
and after that I run UE by a LimeSDR board on another computer with following command
sudo -E ./lte-uesoftmodem --rf-config-file …/…/…/targets/ARCH/LMSSDR/LimeSDR_above_1p8GHz.ini -C 2350000000 -r 25 --noS1 --nokrnmod 0 --ue-txgain 20 --ue-rxgain 50 --ue-scan-carrier
But unfortunately, UE doesn’t connect to enb and after prints some outputs that were brought as follow, it prints "No cell synchronization found, abandoning"
[PHY] Not yet implemented: noise power calculation when prefix length == EXTENDED
[PHY] [UE0] Initial sync : Estimated power: 30 dB
[PHY] [initial_sync] trying carrier off 7500 Hz, rxgain 0 (DL 2350007500, UL 2350007500)
[LMS] rx frequency:2350.007500;
cal 0: freq 3500000000.000000, offset 44.000000, diff 1149992500.000000
cal 1: freq 2660000000.000000, offset 55.000000, diff 309992500.000000
cal 2: freq 2300000000.000000, offset 54.000000, diff 50007500.000000
cal 3: freq 1880000000.000000, offset 54.000000, diff 470007500.000000
cal 4: freq 816000000.000000, offset 79.000000, diff 1534007500.000000
[PHY] [UE thread Synch] Running Initial Synch (mode 0)
[PHY] Initializing frame parms for N_RB_DL 25, Ncp 0, osf 1
[PHY] lte_parms.c: Setting N_RB_DL to 25, ofdm_symbol_size 512
[PHY] [UE] lte_sync_time: Sync source = 1, Peak found at pos 30144, val = 213756 (26 dB)
[PHY] Initializing frame parms for N_RB_DL 25, Ncp 1, osf 1
[PHY] FeMBMS CAS Extended prefix: CellId 148 metric 26, phase 4, flip 1, pbch -1
[PHY] [initial_sync] No cell synchronization found, abandoning
[PHY] Dummping Frame … bye bye
If someone knows how to fix this problem, please let me know.
thanks in advance,
Kumo
