Hi All,
I need you help for the function getHardwareTime from SoapySDR,
Can someone explain me how this function work, Every time I try to get the time from this function, this function return me 0. What this function need to work properly ?
Thanks for you help !
Jerome
You can view the code I use to test the function below:
import SoapySDR
from SoapySDR import * #SOAPY_SDR_ constants
import numpy as np
import pyqtgraph as pg
import time
def generateTxBuffer(Samplerate,SignalTime,FreqSignal,Amplitude=0.3):
#SampleRate must be 10 * Frequency Signal
x = np.linspace(0, SignalTime , Samplerate*SignalTime)
y= Amplitude*np.sin(2*np.pi*FreqSignal* x).astype(np.complex64)
return x,y
#- init variable
Sample_rateRX = 5e6 # hz
Sample_rateTX = 5e6 # hz
rxChan=0
txChan=0
AntennaRX=‘LNAL’
AntennaTX=‘BAND1’
GainRX= 20 #db
GainTX = 0 #db
FrequencyRX= 2.4e9 #hz
FrequencyTX= 2.4e9 #hz
Pulse_lenght= 1 #second
Pulse_frequency= 50000 # hz
Pulse_amplitude= 0.3
RXbuffer_time= 3 #second
Receive_RX_buffer_lenght= 2 #second
#- init SDR
args = dict(driver=“lime”)
sdr = SoapySDR.Device(args)
if not sdr.hasHardwareTime():
raise Exception(‘this device does not support timed streaming’)
#- Set sample rate RX & TX
sdr.setSampleRate(SOAPY_SDR_RX, rxChan, Sample_rateRX)
sdr.setSampleRate(SOAPY_SDR_TX, txChan, Sample_rateTX)
print(“Actual Rx Rate %f Msps”%(sdr.getSampleRate(SOAPY_SDR_RX, rxChan)/1e6))
print(“Actual Tx Rate %f Msps”%(sdr.getSampleRate(SOAPY_SDR_TX, txChan)/1e6))
#- Set Antenna RX & TX
sdr.setAntenna(SOAPY_SDR_RX, rxChan, AntennaRX)
sdr.setAntenna(SOAPY_SDR_TX, txChan, AntennaTX)
#- Set Gain RX & TX
sdr.setGain(SOAPY_SDR_RX, rxChan,GainRX)
sdr.setGain(SOAPY_SDR_TX, rxChan, GainTX)
#- Set Frequency RX & TX
sdr.setFrequency(SOAPY_SDR_RX, rxChan , FrequencyRX)
sdr.setFrequency(SOAPY_SDR_TX, txChan , FrequencyTX)
print(“Create Rx and Tx streams”)
rxStream = sdr.setupStream(SOAPY_SDR_RX, SOAPY_SDR_CF32,[rxChan])
txStream = sdr.setupStream(SOAPY_SDR_TX, SOAPY_SDR_CF32,[txChan])
time.sleep(1) #sleep to activate the configuration
#- TX send buffer
sdr.activateStream(txStream)
x,txPulse = generateTxBuffer(Sample_rateTX,Pulse_lenght,Pulse_frequency,Pulse_amplitude)
print(“Time:”,sdr.getHardwareTime())
#- Transmit & receive data
#- Cleanup streams
print(“Cleanup streams”)
sdr.deactivateStream(txStream)
sdr.closeStream(rxStream)
sdr.closeStream(txStream)
