Hi there.
While trying to flash my LimeSDR-USB after update Lime Suite, process failed, and now the device appears to USB bus as Cypress (FPGA?). Neither LimeUtil nor LimeSuiteGUI recognizes the device so cannot reflash firmware or gateware.
I’m not shy to solder and have access to a JTAG programmer, but if anyone can provide some guidance I’ll be most grateful.
O.S. is Ubuntu 16.04. Logs follows.
Before:
ismael@ciclon:~$ LimeUtil --info
######################################################LimeSuite information summary
Version information:
Library version: v17.12.0-myriadrf~xenial
Build timestamp: 2017-12-13
Interface version: v2017.12.0
Binary interface: 17.12-1System resources:
Installation root: /usr
User home directory: /home/ismael
App data directory: /home/ismael/.local/share/LimeSuite
Config directory: /home/ismael/.limesuite
Image search paths:
- /home/ismael/.local/share/LimeSuite/images
- /usr/share/LimeSuite/imagesSupported connections:
- PCIEXillybus
- STREAM
- uLimeSDR
syslog:
[143255.272131] usb 2-2: new SuperSpeed USB device number 11 using xhci_hcd
[143255.288933] usb 2-2: LPM exit latency is zeroed, disabling LPM.
[143255.289727] usb 2-2: New USB device found, idVendor=1d50, idProduct=6108
[143255.289735] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[143255.289740] usb 2-2: Product: LimeSDR-USB
[143255.289744] usb 2-2: Manufacturer: Myriad-RF
[143255.289747] usb 2-2: SerialNumber: 0009060B00472830
Flash:
ismael@ciclon:~$ LimeUtil --update
Connected to [LimeSDR-USB [USB 3.0] 9060B00472830]
Firmware version mismatch!
Expected firmware version 4, but found version 3
Lime Suite - Myriad-RF Wiki
Gateware version mismatch!
Expected gateware version 2, revision 12
But found version 2, revision 6
Estimated reference clock 30.7199 MHz
Reference clock 30.720 MHz
[ 10%] 18176/185976 Bytes Programming failed! Write operation failed (/usr/share/LimeSuite/images/17.12/LimeSDR-USB_HW_1.4_r4.0.img)
Programming update failed! : Programming failed! Write operation failed
After:
Connected to [WestBridge [USB 2.0] 4BE]
Unsupported hardware connected: UNKNOWN[HW=0]
Programming update failed! : Unsupported hardware connected: UNKNOWN[HW=0]
syslog:
[143271.192107] usb 1-11.1: new high-speed USB device number 37 using xhci_hcd
[143271.292716] usb 1-11.1: New USB device found, idVendor=04b4, idProduct=00f3
[143271.292724] usb 1-11.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[143271.292729] usb 1-11.1: Product: WestBridge
[143271.292733] usb 1-11.1: Manufacturer: Cypress
[143271.292736] usb 1-11.1: SerialNumber: 0000000004BE
[143282.272340] usb 1-11: reset high-speed USB device number 35 using xhci_hcd
[143282.700347] usb 1-11.1: reset high-speed USB device number 37 using xhci_hcd
lsusb:
Bus 001 Device 010: ID 04b4:00f3 Cypress Semiconductor Corp.
