well thanks a lot, including the new limesuite.dll has reduced all those warnings and errors as declared at Missing functions.
But now i still get the following errors and warnings:
limeSDR.build_thunk
Warning: The function ‘LMS_Disconnect’ was not found in the libraryIn loadlibrary at 402
In limeSDR>limeSDR.build_thunk at 127
Warning: The function ‘LMS_IsOpen’ was not found in the library
Warning: The data type ‘FcnPtr’ used by function LMS_Program does not exist.
Warning: The data type ‘FcnPtr’ used by function LMS_ProgramUpdate does not exist.
Warning: The function ‘LMS_ProgramUpdate’ was not found in the library
Warning: The data type ‘FcnPtr’ used by function LMS_RegisterLogHandler does not exist.
In limeSDR>limeSDR.build_thunk at 127Missing functions:
‘LMS_Disconnect’
‘LMS_IsOpen’
‘LMS_ProgramUpdate’Error using limeSDR.build_thunk (line 144)
Failed to find the above functions in libLimeSuite.
