where do i find the library : LimeSuite.dll ??
Can someone quickly help?
Thanks
Thanks
answer from https://wiki.myriadrf.org/Installing_Lime_Suite_on_Windows
download the latest version from Myriad’s website: https://downloads.myriadrf.org/builds/PothosSDR/
and install the PothosSDR bundle to install LimeSuite.dll
Will this also solve this problem: Missing functions ??
well thanks a lot, including the new limesuite.dll has reduced all those warnings and errors as declared at Missing functions.
But now i still get the following errors and warnings:
limeSDR.build_thunk
Warning: The function ‘LMS_Disconnect’ was not found in the libraryIn loadlibrary at 402
In limeSDR>limeSDR.build_thunk at 127
Warning: The function ‘LMS_IsOpen’ was not found in the library
Warning: The data type ‘FcnPtr’ used by function LMS_Program does not exist.
Warning: The data type ‘FcnPtr’ used by function LMS_ProgramUpdate does not exist.
Warning: The function ‘LMS_ProgramUpdate’ was not found in the library
Warning: The data type ‘FcnPtr’ used by function LMS_RegisterLogHandler does not exist.
In limeSDR>limeSDR.build_thunk at 127Missing functions:
‘LMS_Disconnect’
‘LMS_IsOpen’
‘LMS_ProgramUpdate’Error using limeSDR.build_thunk (line 144)
Failed to find the above functions in libLimeSuite.
maybe you can find a comparable function here: https://github.com/myriadrf/LimeSuite/tree/master/src/lime
or here: Using APIs for LimeSDR Mini
Alright man, thanks a lot. That clears up all the errors, the help from last post does!!
But there still are warnings:
limeSDR.build_thunk
Warning: The data type ‘FcnPtr’ used by function LMS_Program does not exist.In loadlibrary at 402
Warning: Encountered the following warnings while loading libLimeSuite:
LimeSuite.hType ‘lconvPtr’ was not found. Defaulting to type voidPtr.
Found on line 5512 of input from line 2018 of file C:\Program Files (x86)\Microsoft Visual Studio
11.0\VC\INCLUDE\crtdefs.hType ‘longdouble’ was not found. Defaulting to type error.
Found on line 10074 of input from line 139 of file C:\Program Files (x86)\Microsoft Visual Studio
11.0\VC\INCLUDE\stdlib.hFunction pointer types are unsupported in structures enum { LMS_FMT_F32 = .
Found on line 12695 of input from line 1089 of file C:\Users\VINAYAK
KARANDIKAR\Documents\MATLAB\MATLAB\Master_Thesis\Testing_Reception_From_Signal_Generator\Fourth_Test\LimeSuite.h
libLimeSuite_thunk_pcwin64.c
Creating library libLimeSuite_thunk_pcwin64.lib and object libLimeSuite_thunk_pcwin64.expIn limeSDR>limeSDR.build_thunk at 148
I’m not sure when the data type ‘FcnPtr’ went away. Now, the function LMS_RegisterLogHandler takes a parameter of type LMS_LogHandler. See the excerpt bellow from lime/LimeSuite.h
Yes, i did spot that part in LimeSuite.h
So how do we remove the above warnings? Any ideas?
I’ve never used limeSDR.build_thunk, or MATLAB. I do not have any idea.
