I’ve spent a good amount of time trying to follow along with the Manual Calibration of the RX Path found here: https://wiki.myriadrf.org/Getting_Started_with_LimeSDR-USB_and_LimeSuiteGUI
However, despite following all the other steps as outlined in the guide, I’m unable to reproduce figure 19 from section 9. In the FFTviewer, the time plot just shows static and the constellation diagram is a tiny blob of points, rather than the waveform or set of points as depicted. I see the three peaks in the spectrum, but it’s very noisy and changing phase, I, or Q doesn’t seem to have an effect any of the peaks.
What exactly is the minimum set of steps for using LimeSuite to calibrate the RX side? From my experience, calibrating TX works fine, but it’s RX that’s having issues.
Thanks!
