I wasn’t sure if I should do it after or before using my test program above, so I did both. Here are the respective files for the old and new hardware:
- Dump of old hardware after plugging it in (before test)
- Dump of old hardware after running the test program that failed with MCU error 3
- Dump of new hardware after plugging it in (before test)
- Dump of new hardware after running the test program that failed with MCU error 3
Note that my test was done on FreeBSD (with the USB reset omitted yet, we’re still working on fixing that for FreeBSD). If necessary, I can repeat them on Linux.
Amendment:
When I let the test program run, the LimeSuiteGUI was closed. I ran the test program (that caused MCU error 3), then started LimeSuiteGUI afterwards, connected to the board, and saved the dump.
If I need to keep LimeSuiteGUI open during the test, let me know, please. I would then redo the dump (in whichever way needed).
