My Limesdr mini has Oversampling either in RX and TX.
I do not understand how to use that features … ie … if i set Sample Rate to 2Mbit/sec i expect to get 2 million samples for second … what happen if i set oversampling = 2 ?
Is there some document to read for understanding how it works ?
Tnx, Fabio,
The LMS7002M RFIC architecture is described in the datasheet:
https://wiki.myriadrf.org/LimeMicro:LMS7002M_Datasheet
If you change the oversampling, the chip will decimate the data on RX by that amount - so if you set the chip to deliver 100kSample/sec to you, and you set oversampling to 16, the chip will internally sample at 1.6MSample/sec, then use a digital filter to reduce the data by 16. On transmit, if you set the chip to take 100kSample/sec and you set 16x oversampling, the chip will take the 100kSample/sec from you, use a digital filter to increase the number of samples by 16, and run internally at 1.6MSample/sec.
This is done for a few cases:
- you want to frequency hop very quickly in a limited bandwidth - you can set the chip to run 65MSample/sec, and then digitally tune +/- 16MHz within that pretty much instantly, and by using the oversampling you can reduce the amount of data you get to something manageable.
- You want to operate below 30MHz, which is the lowest the analog section can tune. So you tune to 30MHz, run the internal sampling at 60Msample/sec, and then tune the digital NCO to the desired frequency and decimate.
Tnx David for informations, now it seems more clear. I understand however that the sample rate i get out of the usb interface is what I’ve set. The oversampling is performed at the RF side. For quickly frequency hop i guess you refer to changing NCO value on the fly. I have the LimeSDRmini so may be that i cannot go too much under 30 Mhz, since the NCO in my case is unable from -7.5 to 7.5 mhz so at best i can go down to 22.5 mhz.
Just to recap, suppose i want to tune at 50 Mhz with 3 Mhz band coverage (from 48.5 Mhz to 51.5 Mhz) with a resolution span of 100 Khz. So i set che chip sample rate at 200 Ks/sec but i set the oversampling at 16 so the rf sampling is internally done at 3.2 Mbit/sec (200*16). Then i can move the frequency with the NCO tuned from --1.6 Mhz to 1.6 Mhz to cover the whole band i want to observe.
Let me know if i understand well.
Tnx, Fabio IZ0IBA
You have it. The only thing I would point out is that if you want 100kHz bandwidth, you don’t need 200kSample/sec since the samples are complex (I and Q) - 200kSample/sec will give you 200kHz bandwidth. Of course, if you want to have 100kHz of flat bandwidth, you might run a higher sample rate so that you can have an equalization filter to flatten the middle of the response out, and have a bit of “slop” at the edges.
