I’m using the LMS7002M in a custom application, but this question should also apply to the rest of the LimeSDR community: What is the load impedance of the LMS7 ADCs? If programmable (I believe this was programmable on the LMS6002D to external resistors), what are the programmable settings?
Specifically, I’m trying to calculate the full-scale input power to the ADC in dBm. While ambiguous with its label (it should be labeled “Full-Scale Input Amplitude”), the spec sheet v2.8 claims the “ADC Input Amplitude” is 0.8 Vpp. Please correct me if I’m wrong in assuming this is the full-scale amplitude corresponding to the maximum-value codeword from the ADC.
What’s interesting is that the dBFS value is used as a reference condition for the SFDR specification, but the dBFS value is not given anywhere else. I’ve also scoured the programming manual and other documentation before posting here.
I believe the last number to solve is the ADC impedance, then you can calculate everything from there. I’m following the procedure from this Analog Devices blog:
Also a great reference for the community for folks new to these calculations and why they matter: http://www.analog.com/media/en/training-seminars/tutorials/MT-003.pdf
Thank you very much for you help.
