Lms-suit installation
Having problems installing lms-suit for LMS6002D.
After downloading from GIT hub (GitHub - myriadrf/lms-suite: Control and FFT software for the Lime Microsystems LMS family of transceivers), I have tried to follow the “Compilation guide windows” that was located lms-suit/docs.
Basically done the following steps:
  1. installed CMake
  2. installed Visual Studio (community)
  3. installed wxWidgets
  4. Build wxwidget library using VS, no errors.
  5. installed EZ-USB FX3 SDK
  6. extracted FFTW
  7. copied lms-suit folder from lms-suite-master\LMS6002D to c:\
  8. ran cmake, no errors reported after giving it correct FFTW path.
  9. opened up lms-suit.sln from the build directory and the tried to build it with VS. However here is where I get two errors, and I am not sure what I am missing, or which step that could have caused the errors.
    Both errors are in OpenGLGraph.cpp
Hoping anyone can help :slightly_smiling:
Found a solution. Seems that I used a version of vxwidgets that is to new.
So I reinstalled VS 2013 and wxwidget 3.0.2, and its working :slight_smile:
