If I read the stream status of a stream that works with
LMS_GetStreamStatus(&m_stream_handle[i], &m_stream_status[i]));
This line
std::cout << "Stream " << i << ": Timestamp: " << m_stream_status[i].timestamp << std::endl;
produces output 0. However, using the meta data connected to the stream like
std::cout << "Stream " << i << ": Timestamp: " << m_stream_meta[i].timestamp << std::endl;
it seems to work as it outputs the timer which goes up by the buffer size of the stream. Why is that?
Here comes the declaration part.
lms_stream_t m_stream_handle[NUMBER_OF_CHANNELS];
lms_stream_status_t m_stream_status[NUMBER_OF_CHANNELS];
lms_stream_meta_t m_stream_meta[NUMBER_OF_CHANNELS];
LMS_GetStreamStatus returns 0.
