I notice that the kernel detects the LimeSDR when attached and I notice this message printed out:
LPM exit latency is zeroed, disabling LPM.
From the kernel source:
* According to the USB 3.0 spec, all USB 3.0 devices must support LPM.
* However, there are some that don’t, and they set the U1/U2 exit
* latencies to zero.
if (!udev->bos->ss_cap) {
dev_info(&udev->dev, “No LPM exit latency info found, disabling LPM.\n”);
return 0;
This seems like a good feature to have enabled when you have a device that is not always active. But maybe I am misunderstanding LPM.
This article leads me to this conclusion:
https://lwn.net/Articles/498068/
Is it possible to enable this feature with the current code? Or would the code (i.e. firmware) require modification? Or is this not possible at all?
