Hi guys,
I am using LimeUtil to calibrate my custom board based on LMS7002M LimeSuite library modified for SPI connection . Firstly,I have made following modifications to LimeUtilCalSweep.c.
a) Changed the reciever path to LNAH in Rx and changed the transmitter path to Band2 in Tx .
b) Set the reference frequency to 40MHz .
c) Replaced LMS_SetLOFrequency to LMS_SetClockFreq
I get the following errors -
a) MCU calibration fails for Channel A , Channel B RX and Channel A TX.(Signal too weak or not connected) . It only passes for Channel B TX . EDIT:There was a problem with channel configuration . Now it fails for RX path LNAH for both Channel A and B.
What could be the reason for this strange behaviour ?
Hi , I just found something . LNAH calibration .
This tells that LNAH cannot be used for automatic calibration . Is this true for LimeSuite in general?
Hi @Zack, I am trying to calibrate over frequencies 2.2GHz to 2.3GHz . LNAH is not working with any combination with Band1 in this range . What should I look into at this point ?
@Zack , I am using LimeSuite library on headless server and hence my system has no GUI . I tried your suggestions by writing directly to the LMS register . I am using the function LMS_WriteLMSReg(device,0x011C,0xA943) .
Meanwhile, I tried with other start and stop frequencies(400MHz to 500Mhz). The result is the same . It always fails for the combination LNAH , Band1 .
Hi @Zack ,
Sorry to disturb you but could you provide some input on this issue .
Meanwhile, I tried with other start and stop frequencies(400MHz to 500Mhz). The result is the same . Calibration always fails for the combination LNAH , Band1 .
Hi @Zack,
The hardware is quite similar to Lime Mini . We are able to do most of the things but calibration for LNAH is crucial .
I can send you the schematics and PCB design files if you want them in your personal mail .
