Following is my configuration:
// RF parameters
config.channel[0].rx.enabled = true;
config.channel[0].rx.gain[eGainTypes::GENERIC] = Gain;
config.channel[0].rx.centerFrequency = CenterFreq;
config.channel[0].rx.sampleRate = SampleFreq;
config.channel[0].rx.oversample = OverSample;
config.channel[0].rx.lpf = BandWidth;
config.channel[0].rx.path = Antenna;
config.channel[0].rx.calibrate = Calibrate;
config.channel[0].rx.testSignal.enabled = true;
Regarding gain - What gain type should I use ?
Is there more that one gain type that I should set ?
Thank you,
Zvi
