Are you compiling debug or release version?
Actually, this is wxWidgets asserts. Try to uncheck “Show this dialog nex time” and press Continue. FFTViewer should work.
installed from ppa. unchecking the box seemed to work. Thank you.
Yes, thank you! Had exact same error, ppa install - unchecking the box worked here also - great!!
This kind of asserts should appear when it is compiled for debug. Could you please describe a compilation procedure you are using just to help identify this issue.
sudo apt-get install limesuite limesuite-udev soapysdr-module-lms7
from the ppa deb http://ppa.launchpad.net/myriadrf/drivers/ubuntu xenial main
Ubuntu 16.10
