Hey folks - just getting started with my new LimeSDR on MacOSX (11.2.3 / Big Sur).
I successfully installed LimeSuite via homebrew (pothosware/pothos/limesuite 20.01.0).
However, when I run it I get the following:
objc[49323]: Class wxNSAppController is implemented in both /usr/local/Cellar/wxmac/3.0.5.1_1/lib/libwx_osx_cocoau_core-3.0.0.5.0.dylib (0x10239cc50) and /usr/local/opt/wxmac/lib/libwx_osx_cocoau_core-3.0.dylib (0x1019c3c50). One of the two will be used. Which one is undefined.
objc[49323]: Class ModalDialogDelegate is implemented in both /usr/local/Cellar/wxmac/3.0.5.1_1/lib/libwx_osx_cocoau_core-3.0.0.5.0.dylib (0x10239cc78) and /usr/local/opt/wxmac/lib/libwx_osx_cocoau_core-3.0.dylib (0x1019c3c78). One of the two will be used. Which one is undefined.
objc[49323]: Class wxNSApplication is implemented in both /usr/local/Cellar/wxmac/3.0.5.1_1/lib/libwx_osx_cocoau_core-3.0.0.5.0.dylib (0x10239ccc8) and /usr/local/opt/wxmac/lib/libwx_osx_cocoau_core-3.0.dylib (0x1019c3cc8). One of the two will be used. Which one is undefined.
objc[49323]: Class wxCPWCDelegate is implemented in both /usr/local/Cellar/wxmac/3.0.5.1_1/lib/libwx_osx_cocoau_core-3.0.0.5.0.dylib (0x10239cd18) and /usr/local/opt/wxmac/lib/libwx_osx_cocoau_core-3.0.dylib (0x1019c3d18). One of the two will be used. Which one is undefined.
<<< snip >>>
./src/common/object.cpp(251): assert "classTable->Get(m_className) == NULL" failed in Register(): Class "wxHVScrolledWindow" already in RTTI table - have you used IMPLEMENT_DYNAMIC_CLASS() multiple times or linked some object file twice)?
./src/common/object.cpp(251): assert "classTable->Get(m_className) == NULL" failed in Register(): Class "wxXmlResourceHandler" already in RTTI table - have you used IMPLEMENT_DYNAMIC_CLASS() multiple times or linked some object file twice)?
zsh: segmentation fault LimeSuiteGUI
joe@Dojos-MacBook-Pro ~ %
I’m not exactly sure how to debug what’s going on . Has anyone else seen this or have an idea on how to proceed? Thanks!
-Joe
