Some open-source software projects utilize Ettus USRP SDRs and therefore also make use of the USRP Sink blocks in their GNU Radio flowcharts. What I am wondering is if there is a difference in terms of what the LimeSuite Sink block and this USRP Sink block take as inputs when we use them to transmit signals.
More specifically, if there is a difference in what must be fed to either sink for the case of transmitting generated WIFI signal.
I am attempting to convert a flowchart from using USRP devices to use a LimeSDR-USB.
There is no difference in input signals. Also note that with UHD plugins in SoapySDR you can directly use USRP Sink to send the data to LimeSDR.
