Hi All,
I just downloaded the most recent copy of the most recent LimeSuite (20171115) and I am running the most recent firmware and gateware in a V1.4 USB type-A plug board.
LimeSuite displays the error:
Failed to load file: Read(64 bytes) failed
I have searched, and these two posts (https://discourse.myriadrf.org/t/failed-to-load-file-when-test-the-limesdr-with-the-self-test-ini/1475/9) and (https://discourse.myriadrf.org/t/failure-to-load-ini-file-and-tests-fail/1408/3) didn’t provide any relief. I have tried with LimeSuite 2017.11.01-vc14 as well.
System is Win10. I have a good interface otherwise to the unit as I am able to use SoapySDR/GNURadio to control it and gather samples. I wanted to go through the test protocols to work out some antenna issues and it appears that I can’t.
If anyone has other suggestions, I’d be glad to hear them.
Cheers
Will
