Want to ping everyone (especially application developers) that LimeSuite 19.01 and related gateware (for LimeSDR-USB and LimeSDR-Mini boards) updates are just about to release. The latest LimeSuite is in master branch as well as related gatewares. Change logs are here:
On Mini I have problem with DC calibration. On RX no effect automatic or manual settings. On TX VHF part is ok but when I try HF mode 30MHz carrier wont go away after LMS_Calibrate function (manualy I can null 30MHz signal). On spectrum analyzer I can see several very fast spikes over 30MHz almost like calibration routine try to null signals in up-convert mode?
changes to LMS_VCTCXOWrite and LMS_VCTCXORead change in prototypes are already known to cause trouble but this is not a big deal. Edit: this is not true anymore since commit 11 days ago.
You may also want to give Simon Simon G4ELI a heads up as well since he went through great pains to get SDRConsole out to the masses and the gateware change may affect his Windows app, too.
