Hey People,
I’ve been struggling to get my LimeSDR working with trunk recorder. Has anyone had success with this?
I do have it working in gqrx, can see the signal in the waterfall etc…
The issue I’m having appears to be not being able to get the control channel tuned in. This is the truncated output from the app when I run it:
[2018-12-19 22:49:26.785436] (info) Capture Directory: /home/alex/sdraudio
[2018-12-19 22:49:26.785476] (info) Upload Server:
[2018-12-19 22:49:26.785502] (info) Status Server:
[2018-12-19 22:49:26.785534] (info) Instance Key:
[2018-12-19 22:49:26.785561] (info) Instance Id:
[2018-12-19 22:49:26.785583] (info) Default Mode: digital
[2018-12-19 22:49:26.785599] (info) Call Timeout (seconds): 3
[2018-12-19 22:49:26.785641] (info) Log to File: false
[2018-12-19 22:49:26.785674] (info) Control channel warning rate: 10
[2018-12-19 22:49:26.785691] (info) Control channel retune limit: 0
[2018-12-19 22:49:26.785744] (info) Frequency format: 0
[2018-12-19 22:49:26.785764] (info) Status as String: false
[2018-12-19 22:49:26.785842] (info) [nswgrn] Started with Control Channel: 4.161250e+08
[2018-12-19 22:49:26.785975] (info) SmartNet Trunking - SysNum: 0
[2018-12-19 22:49:26.786001] (info) Control channel: 4.16125e+08
[2018-12-19 22:49:26.791147] (info) P25 Recorder Initial Rate: 512000 Resampled Rate: 36571.4 Initial Decimation: 8 Decimation: 14 System Rate: 36000 ARB Rate: 0.984375
[INFO] Rx calibration finished
[2018-12-19 22:49:30.005496] (info) Pll Phase: 6.10877 min Freq: -3.141593e-01 Max Freq: 3.141593e-01
[2018-12-19 22:49:30.005777] (error) [nswgrn] Retuning to Control Channel: 4.161750e+08
[2018-12-19 22:49:30.005863] (info) - System Source - Min Freq: 4.139520e+08 Max Freq: 4.180480e+08
[2018-12-19 22:49:30.006376] (info) Offset set to: 175000 Freq: 4.161750e+08
[2018-12-19 22:49:30.006457] (error) [nswgrn] Control Channel Message Decode Rate: 0/sec, count: 0
[2018-12-19 22:49:33.006567] (info) Pll Phase: -1.5619 min Freq: -3.141593e-01 Max Freq: 3.141593e-01
[2018-12-19 22:49:33.006741] (error) [nswgrn] Retuning to Control Channel: 4.169250e+08
[2018-12-19 22:49:33.006805] (info) - System Source - Min Freq: 4.139520e+08 Max Freq: 4.180480e+08
[2018-12-19 22:49:33.007193] (info) Offset set to: 925000 Freq: 4.169250e+08
[2018-12-19 22:49:33.007259] (error) [nswgrn] Control Channel Message Decode Rate: 0/sec, count: 0
I’m so lost with this I don’t even know where to start…
