I’m trying to make a timed burst transmitter using LimeSDR with the SoapySDR python module. Calls to mysdr.hasHardwareTime() returns True but all subsequent calls to mysdr.getHardwareTime() return 0 ns. Example code:
import SoapySDR
from SoapySDR import *
import time
args = dict(driver="lime")
sdr = SoapySDR.Device(args)
print sdr.hasHardwareTime()
while True:
print sdr.getHardwareTime()
time.sleep(1.0)
All of this works on a USRP B200. Does LimeSDR really have a hardware timer? Am I doing something wrong?
Thanks for your help. Confirmed that it works and will probably suit my application well.
I’m still a bit confused though. activateStream() and deactivateStream() have optional time parameters. How can one activate a stream at a certain time if the hardware timer isn’t running until the stream is activated? The MeasureDelay.py example uses this feature.
