I deleted the project and created a new one. Same issue it thinks I am using a sink but I am only using a source. Here is a screen shot. I will mostly need to rebuild gnuradio and osmocom back into the it. It has to be corrupt
.This looks more like a bug in the Osmocom ↔ SoapySDR connection. That should not happen.
FWIW I tested locally that I can use an Osmocom source with antenna set to LNAW and RX BW set to 2 MHz and it works. Either different software version or exposed issue somewhere.
Hopefully Brew install should work now:
