Hello all,
The LimeSDR USB is showing TransfertPacket errors during LimeQuickTest.
I using ubuntu 18.04, 20.04 and windows 10 operating system.
I update the LimeSDB USB board with latest firmawre with the command line : LimeUtil --update
I didn’t have any errors and firmawre as bee updated, I put the log at the end of the message.
The board is correctly detected on USB with ubuntu 22.04 and 18.04.
The LimeQuickTest return lots of errors during TransfertPacket, but I don’t know what it means.
I tested with LimeSuiteGUI version 23.11.0-11, I can connect the LimeSDR-USB device, read TEMP and Reset, but loading self_test.ini file failed with error “Failed to load file” and ERROR: TransferPacket: Read failed (ret=0), then the board is frozen. I need to disconnect and reconnect USB to recover it.
Could you help me please to fix this issue ?
Regards,
Nyme.
$ LimeUtil --info
LimeSuite information summary
Version information:
Library version: v22.09.0-ge829d3ed
Build timestamp: 2024-01-27
Interface version: v2020.10.0
Binary interface: 22.09-1
System resources:
Installation root: /usr/local
User home directory: /home/ackwel
App data directory: /home/ackwel/.local/share/LimeSuite
Config directory: /home/ackwel/.limesuite
Image search paths:
- /home/ackwel/.local/share/LimeSuite/images
Supported connections:
- FT601
- FX3
- PCIEXillybus
$ lsusb
Bus 001 Device 011: ID 1d50:6108 OpenMoko, Inc. Myriad-RF LimeSDR
$ LimeQuickTest
->Start time: Sun Jan 28 15:42:03 2024
->LimeSuite version: 22.09.0-ge829d3ed
->Device: LimeSDR-USB, media=USB 2.0, module=FX3, addr=1d50:6108, serial=0009081C05C31438, HW=4, GW=2.23
Warning: USB3 not available
Serial Number: 0009081C05C31438
Chip temperature: 45 C
->FX3 GPIF clock test
Test results: 29673; 33429; 37185 - PASSED
->Si5351C test
CLK0: 17554 / 17554 - PASSED
CLK1: 17554 / 17554 - PASSED
CLK2: 17554 / 17554 - PASSED
CLK3: 17554 / 17554 - PASSED
CLK4: 17554 / 17554 - PASSED
CLK5: 17554 / 17554 - PASSED
CLK6: 17554 / 17554 - PASSED
->ADF4002 Test
Result: 10 - PASSED
Results : 5112968 (min); 5113106 (max) - PASSED
->Clock Network Test PASSED
->Read data: 13 01 1D 13 01 1D 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
TransferPacket: Write failed (ret=0)
