So, I am trying to prove, or disprove the true need for an external power supply on a LimeSDR USB.
Using SDR-Console, with 40 Mhz/24 receivers & a quality USB3.0 hub (Measured able to provide a solid 2 amps) & am only drawing 724ma.
What I would like, is a script to max out the unit on amperage draw to see what the max draw will be.
I jumped out the (NF) R167 for bypassing my popped IC25 power switch.
So, I am using Win10 Pro, but will do a Linux OS if needed to test this.
Testing will be on a Dell 5500 2-Xeon 4 core 3.2MHz with 72 GB Ram & a GTX 960 video card.
Please see what you can find to help me find the max amp draw on this unit.
Thank you,
Ed
