I am trying to characterize the Tx of my limeSDR mini. I connected the limeSDR_Tx directly into a spectrum analyser, transmitted a sine wave by using GNURadio and measured the power [dBm] using the spectrum. I encountered 2 issues:
Max power is -17dBm as oppose to the expected 10 dBm.
The power output is very unstable, get a peak every 100 MHz approximately and then the signal falls back down.
I repeated a similar procedure with limeSDR (not mini) and encountered similar values, so it’s probably not the specific device that is broken.
Here are two images, the right one is a scan over the peak frequencies, to see the overall performance and the left one is a scan with a smaller step of 5 MHz around 900 MHz to demonstrate the unstable amplitude I’m seeing.
Thanks Karl. Tried those, don’t think it’s the issue.
The temp looks good, don’t know the exact value, but the chip is hardly warm.
The USB voltage reading is 4.7-4.93 volts (tried few different ports). Also, I checked the current difference between the transmitting and the idle modes, got a delta of 40 mA, so 10log10(4.9x0.04/1e-3) = 23 dBm is going into the device.
I also tried calibrating the SDR using limesuit and afterwards loading this from gnuradio, this gave me even worst performance and changing the Tx band which also didn’t help.
