Hello.
After flashing the device, it stopped displaying.
Is it possible to reset the firmware and if so, how?
(Device: LimeSDR-PCIe v.1.3
I took the firmware from here https://downloads.myriadrf.org/project/limesuite/20.01).
Thanks/
None of these images are for LimeSDR-PCIe. Instructions for programming this board can be found at:
Hello.
I did all the points, according to the description on the link, but during the flashing process, the program quartus gives an error “can’t access JTAG chain”. I believe this is due to the output parameters of the pins. Tell me how you can fix this error?
This is one for @Zack.
Are you sure USB Blaster is connected correctly? Is the board powered up?
Yes of course.
Been on Linux - the same result.
Only the power indicator on the board is on. She is currently in a “brick” state
The problem turned out to be in the programmer: it did not fit with the STM32 circuit. But with the EPM306 circuit everything worked out. Keep in mind if someone collides
@Zack is this something we can note on the wiki?
Could you share programmer you use, please.
