Hello All:
I have received my LimeSDR mini v2! Thank you all!!
I am a little new to the JTAG world and the connection to ECP5 Lattice devices.
I am trying to connect the jtag port and need some advice. I am following this article
Jtag mini
But I am a little confused of how to connect to the FT2232H-56Q mini module that I bought for this purpose.
I found this comment on the eeblog forum, eeblog link
In the post they say to connect the 4 pins to
TDO AD2
TCK AD0
TDI AD1
TMS AD3
GND GND
Is there any more info on how to setup the FT2232H? I have found this link: FT2232H mini module. Is this the correct way?
Also, Does the LimeSDR v2 board have the pull up resistor for TCK? on the board? or do I have to connect that externally?
Then I can use the OpenOCD software to load the bit FPGA file? Am I correct in this? I am working from the Litex-boards project file from here. Litex Boards.
Or should I be posting this question there? (discord)
Sorry for the Noob Question, I am just nervous making connections of the new board and don’t want to blow up 400 to 500 hundred dollar board when I just got it! ![]()
Thanks!
Mike K
VA3TEC
