I bought the original Mini on CrowdSupply but have hardly used it since. In fact, I mostly only got as far as listening to broadcast FM.
I now have a project to use it seriously (< 100Mhz) and first thing I did was run the LimeQuickTest (LimeSuiteVersion 23.11.0-1) and getting a failure on loopback. This seems to be a recurring problem but it appears there are two scenarios: 1) slightly out of tolerance due to temperature; and 2) significantly out of tolerance. Unfortunately, mine is the latter:
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-55.6 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-20.7 dBFS, 5.00 MHz) - PASSED
->RF Loopback Test FAILED
This is backed up by general reception being about 15dbm or more lower than the same setup and circumstances as my LimeNet Micro.
Tracing the signal through, I found that the DC input resistance (not powered and no signal connected) on rfgp_w_RFE_1 (pin AN9) is only 33 ohms, whereas the other input rfgn_w_RFE_1 (pin AP10) is 120kohms. The high band inputs are (RX1_H) are 10Mohms.
Curiously, the input does still work, but I suspect it is unbalanced on the ‘n’ input only and therefore half the expected power.
There seem to be a few other people with -50ish dBFS loopbacks, so was this a manufacturing issue, or has something simply failed?
Is the only remedy to replace the LMS7002 or is it a known problem with this board issue that can be fixed?
I was thinking to take the caps off the RX1_W input and fit them to the RX1_H input but it is a fiddle as I only have limited equipment and skills.
Buying a Mini 2.0 at $399 doesn’t seem that attractive right now.
