My LimeSDR Mini (v1.2) seems to have suffered a failure.
I had it running successfully for a few hours with CubicSDR. I paused the radio receive process, then came back to find the LimeSDR’s LEDs were off and CubicSDR had crashed.
I reconnected the LimeSDR - the LEDs remained off.
I tried LimeQuickTest – this reports “TransferPacket: Read failed” and “TransferPacket: Write failed” errors.
I’ve since bought a USB Blaster and set it up per this article:
https://wiki.myriadrf.org/LimeSDR-Mini_JTAG_cable_adapter#LimeSDR-Mini_JTAG_cable_adapter
And used Quartus Prime Programmer to reprogram the gateware with the image from:
If I load the HW1.2 POF file, the behaviour of the board doesn’t change - when plugged into the USB port the LEDs stay off.
If I load the HW1.2 SOF file, the LEDs light up and the board works okay. When unplugged from the USB port and reconnected, it goes back to the no-LEDs and USB-errors behaviour.
… Well, I say it works okay – I just tried again and I get a failure on the RF loopback test:
->Start time: Fri Mar 19 17:02:53 2021
->LimeSuite version: 20.10.0-myriadrf2~focal
->Device: LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D42598C70F559, HW=2, GW=1.30
Serial Number: 1D42598C70F559
Chip temperature: 34 C
->REF clock test
Test results: 38098; 51295; 64492 - PASSED
Results : 6711046 (min); 6711199 (max) - PASSED
->Clock Network Test PASSED
->Read data: 12 07 1B 12 07 1B 02
->FPGA EEPROM Test PASSED
->LMS7002M Test PASSED
->Run Tests (TX_2 -> LNA_W):
CH0 (SXR=1000.0MHz, SXT=1005.0MHz): Result:(-66.6 dBFS, 5.00 MHz) - FAILED
->Run Tests (TX_1 -> LNA_H):
CH0 (SXR=2100.0MHz, SXT=2105.0MHz): Result:(-55.2 dBFS, 5.00 MHz) - FAILED
->RF Loopback Test FAILED
=> Board tests FAILED <=
Elapsed time: 2.49 seconds
Is there anything else I can try to fix this board – or if not, how can I get it replaced?
Thanks
Phil.
