what is the current way to install all the software to get the LimeSDR mini to work?
Adding the myriadrf ppa doesn’t anymore work like described in this post:
I simply want to use the LimeSDR together with SoapySDR for dump1090 reception.
Please, could someone just put the commands in here to install all the packages that I need?
I have an old min v1.3 and have to use an Pi 3 with bookworm for my application.
I stuck at the first step adding the ppa
pi@wb-home:~ $ sudo add-apt-repository -y ppa:myriadrf/drivers
Repository: 'deb https://ppa.launchpadcontent.net/myriadrf/drivers/ubuntu/ bookworm main'
Description:
This PPA contains various SDR hardware drivers and is maintained by the Myriad-RF Packaging project.
For more details see: https://myriadrf.org/projects/packaging/
More info: https://launchpad.net/~myriadrf/+archive/ubuntu/drivers
Adding repository.
Found existing deb entry in /etc/apt/sources.list.d/myriadrf-ubuntu-drivers-bookworm.list
Adding deb entry to /etc/apt/sources.list.d/myriadrf-ubuntu-drivers-bookworm.list
Found existing deb-src entry in /etc/apt/sources.list.d/myriadrf-ubuntu-drivers-bookworm.list
Adding disabled deb-src entry to /etc/apt/sources.list.d/myriadrf-ubuntu-drivers-bookworm.list
Adding key to /etc/apt/trusted.gpg.d/myriadrf-ubuntu-drivers.gpg with fingerprint 11FC2E68126782B43762694F22C627172ECB91FE
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Ign:5 https://ppa.launchpadcontent.net/myriadrf/drivers/ubuntu bookworm InRelease
Err:6 https://ppa.launchpadcontent.net/myriadrf/drivers/ubuntu bookworm Release
404 Not Found [IP: 2620:2d:4000:1::81 443]
Get:7 https://repositories.timber.io/public/vector/deb/debian bookworm InRelease [3,553 B]
Reading package lists... Done
E: The repository 'https://ppa.launchpadcontent.net/myriadrf/drivers/ubuntu bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
With bookworm I do not think that you need the ppa at all. I did not need them with my install on bookworm 64 bits. I down loaded and installed the new LimeSuite-23.10.0 for my mini 2.0, but the old mini does not need the new LimeSuite. So, I would expect a simple
sudo apt-get install cubicsdr
or
sudo apt-get install gqrx-sdr
would get you a gqrx or CubicSDR that would run the LimeSDR mini
I want to run dump1090 / readsb on a pi, so gqrx or cubicsdr is not the right software for me. Thus I need to install all the SoapySDR and LimeSDR separately.
What of these packages do I actually need? I think only
