Hi there,
I just received my LimeSDR Mini and after trying to use it in both gqrx and gnuradio-companion, I keep running into this error:
[ERROR] MCU working too long 33
[ERROR] setBandwidth(Rx, 0, 30 MHz) Failed -
Error probing device:
I’m using the latest versions of pretty much everything from the Myriad RF, gnuradio, and gqrx PPA’s under Ubuntu 16.04. I’ve installed the udev rules and have ensured they were loaded correctly as well. The commands I’m trying work just fine with my LimeSDR USB on the exact same USB port.
In an effort to dig a little deeper, I installed SoapySDRUtil. the --find command finds the LimeSDR Mini without issue.
However, SoapySDRUtil --probe="driver=lime" still gives the same error as both gqrx and gnuradio-companion. Here is the full output:
Probe device driver=lime
[INFO] Make connection: 'LimeSDR Mini [USB 3.0] <redacted>'
[INFO] Device name: LimeSDR-mini
[INFO] Reference: 40 MHz
[INFO] Init LMS7002M(0)
[INFO] Ver=7, Rev=1, Mask=1
CGEN: Freq=80 MHz, VCO=2.56 GHz, INT=63, FRAC=0, DIV_OUTCH_CGEN=15
CGEN: Freq=61.44 MHz, VCO=2.4576 GHz, INT=60, FRAC=461373, DIV_OUTCH_CGEN=19
M=156, N=3, Fvco=1040.000 MHz
MCU programming : 16384/16384
MCU Programming finished, 2826 ms
I haven’t tested RX/TX with with LimeSuiteGUI yet, because it’s honestly tedious. I’ll try to figure out how to do that now, but without these other tools working, the LimeSDR Mini is going on the shelf.
EDIT: Okay, I tested RX/TX using LimeSuiteGUI as well as the LimeSDR-Mini_QuickTest_1v1 under Windows 10 and it is working okay. I also tested RX/TX under using LimeSuiteGUI under my Linux install and that also works okay. Now it’s just about getting the gnuradio portions of all this working!
Any hints on what might be going on here?
Thanks!
Jamis
P.S. There’s no category for LimeSDR Mini…
