LimeSDR Mini and Spurious signal around 100 MHz
@ Stef : very nice and clever heatsink case design !
I’ve bought a 3mm thermal pad to attach a heatsink and get a noiseless cooling system.
(see GitHub - gasparka/spectrogram: 80MHz bandwidth with LimeSDR-Mini and GQRX)
However I never use my pad since my lime mini is always working properly even if it gets quite hot.
(limesuite shows about 54C for the lms chip)
Now I can’t do anything with all my shielding covers except using a small fan or remove them !
Here are some measurements with my modded lime-mini. Unfortunately I have no measurement before modding and don’t have a S.A.
I try using similars measurements settings as Stef posts
I use a RSP1A Sdrplay SDR (with SDRUno software) to perform RF levels measurements.
This device is known to give quite good accurate power levels values. (+/-1dBm)
Nothing is connected to RSP1A input port :
(settings are : ZIF mode, max lna gain, SR=span=5MHz, no decimation, FFT on 8192pts with 64 averaging windowing=sin^3 ) :
Spectrum is flat, the display average noise level shows less than -143dBm.
A 1m RG316 coax cable is connecting the RSP1A to the lime-mini RX port to check any RF leaks.
The lime is not already connected to usb3 port :
The lime TX port is terminated by a 50ohm load.
Spectrum shows many fm broadcasting stations ! (coax shielding is not perfect…)
Strongest fm signal is at -131dBm level.
Lime-mini is now plugged into the computer usb3 port with a 1m usb3 cable (with ferrites) :
A 100Mhz (-136dBm) spike appears on spectrum.
Limesuite is now running with theses settings :
Initialization with Connected, Reset and Default buttons
CLKGEN Tab : 20MHz to get 20/4=5 MHz rx sample rate
Zoom on spectrum shows now 2 spikes : the first spike is in fact at 99996kHz and the second and new one is at 100000kHz (-122dBm)
After a few seconds the first spike disappears.(it shows again if there are some commands sent from the computer to the limemini)
Now when setting RX frequency tab :
SXR Tab : frequency 100.1MHz Calculate Tune (this value will help to identificate LO spike)
Spectrum shows 100.1Mhz -131dBm wave (LO leaks to RX port)
Calibrations tab : calibrate RX
100.1MHz wave amplitude decreases and increases to same initial level.
FFT viewer windows shows spikes (about 10dB over the noise floor except the center spike)
if we set SXR clock closed to 100MHz :
Comb signal reappear…
At 100.050MHz :
At 100.010MHz :
At 100.000MHz :
RX port is connected to a reference signal generator (100.2Hz -114dBm) :
Comb spurs levels highly depend on gain settings
with default gain settings LNA=Gmax, TIA=Gmax-3, PGA=6dB
Ref. signal (100.2Hz -114dBm) is among spurs spikes.
with these settings LNA=Gmax-15, TIA=Gmax-0, PGA=19dB :
Spurs are greatly reduced but we keep the ref. signal.
It seems that spurs levels highly depend on LNA Gain.
Let’s see the RF spectrum at lime-mini RX port :
A comb signal appears around 100MHz and the level stay under -135dBm
The 100.1MHz LO spike is the strongest (-130dBm)
The 100Mhz spike is a few dB lower.
I remembered interferences and comb signals were so strong that no other signals can be observed before the mod.
Some spectrums at multiples of 100MHz frequency :
(FFT is still running)
Connecting lime-mini TX port to SDR input :
Interferences at Tx port are similar to RX port ones.
I think theses results are far better than before modding.
You can measure on your unmodded lime mini to compare.
I think most of the improvements come from increasing C17 C18 (for the RX part) Shielding also improve interferences level. Even with 3 metal covers there is still interferences around it. Maybe I have to add a global metal enclosure around the device …:joy:
