Does anybody have any idea why I am getting this:
self.limesdr_source_0_0 = limesdr.source(‘1D393786C41058’,
AttributeError: ‘module’ object has no attribute ‘source’
when I try to execute all of the gr-limesdr module examples ?
Hi sgoudelis,
Try to run the following command in terminal and see if it helps you:
sudo ldconfig
Nope that did not help.
Could you list me versions of the following software you are using: Linux/Windows OS, LimeSuite, GNU Radio, gr-limesdr?
Try to uninstall and do clean install of gr-limesdr blocks:
cd gr-limesdr/build
sudo make uninstall
sudo make clean
cd …
sudo rm -rf build
git pull origin master
mkdir build
cd build
cmake …
make
sudo make install
sudo ldconfig
Yeah that worked. Thank you.
