Dear guys,
I want to use my LimeSDR to measure the signal amplitude at a given frequency (here 245 MHz) with small bandwidth, around 1-2 Mhz. But signals which I have from the LimeSDR differ in time despite the fact I use the same settings on signal generators which connected to RX1_L and RX2_L ports. I send -60 dBm, but I receive sometimes -41 dBm, sometimes -39 dBm, and this happens randomly. What I have noticed, is that in general signal from RX2_L is a bit higher than from RX1_L. Even when I switch off the amplifiers by setting amplification to 0 or give them exact amplification coefficient (how does it really gains? is LNA 10 equal to +10dB gain???) I see the same picture - different amplification on time and different amplifications on each channel.
I program LimeSDR with Python 3.6.8 using SoapySDR
Lib Version: v0.7.1-myriadrf1~ubuntu18.04
API Version: v0.7.1
ABI Version: v0.7
I call the command
python3 lime.py --center 246e6 --time 1 --samprate 8e6 --bw 4e6 --channel 1 2 --filename test12.bin test22.bin
where bandwidth and sampling rate are in MHz, measurement time is in seconds.
Here is my code and two plots from measurement of the -60 dBm signals which result as -40.9 dBm and -42.3 dBm.
import numpy as np
import argparse
from matplotlib import pyplot as plt
import SoapySDR
from SoapySDR import SOAPY_SDR_RX, SOAPY_SDR_CS16
class LimeSDR:
#at first one has to initialize SDR. Init method sets all preferences and setups the data streams
def __init__(self, cent_freq, meas_time, rx_bw, fs, channel): #rx_bw - bandwidth, fs - sampling rate
self.channel = channel
use_agc = True # Use or don't use the AGC
self.freq = cent_freq # LO tuning frequency in Hz
self.timeout_us = int(5e6)
self.N = int(fs * meas_time) # Number of complex samples per transfer
self.rx_bits = 12 # The Lime's ADC is 12 bits
RX1 = 0 # RX1 = 0, RX2 = 1
RX2 = 1
self.sdr = SoapySDR.Device(dict(driver="lime")) # Create AIR-T instance
if (len(self.channel) == 2):
self.sdr.setSampleRate(SOAPY_SDR_RX, RX1, fs) # Set sample rate
self.sdr.setSampleRate(SOAPY_SDR_RX, RX2, fs)
self.sdr.setGainMode(SOAPY_SDR_RX, RX1, False) # Set the gain mode
self.sdr.setGainMode(SOAPY_SDR_RX, RX2, False)
self.sdr.setGain(SOAPY_SDR_RX, RX1, "TIA", 0) # Set TransImpedance Amplifier gain
self.sdr.setGain(SOAPY_SDR_RX, RX2, "TIA", 0)
self.sdr.setGain(SOAPY_SDR_RX, RX1, "LNA", 0) # Set Low-Noise Amplifier gain
self.sdr.setGain(SOAPY_SDR_RX, RX2, "LNA", 0)
self.sdr.setGain(SOAPY_SDR_RX, RX1, "PGA", 0) # programmable-gain amplifier (PGA)
self.sdr.setGain(SOAPY_SDR_RX, RX2, "PGA", 0)
self.sdr.setDCOffsetMode(SOAPY_SDR_RX, 0, False)
self.sdr.setDCOffsetMode(SOAPY_SDR_RX, 1, False)
self.sdr.setFrequency(SOAPY_SDR_RX, RX1, self.freq) # Tune the LO
self.sdr.setFrequency(SOAPY_SDR_RX, RX2, self.freq) # Tune the LO
self.RX1_buff = np.empty(2 * self.N, np.int16) # Create memory buffer for data stream
self.RX2_buff = np.empty(2 * self.N, np.int16) # Create memory buffer for data stream
self.sdr.setBandwidth(SOAPY_SDR_RX, RX1, rx_bw)
self.sdr.setBandwidth(SOAPY_SDR_RX, RX2, rx_bw)
self.sdr.setAntenna(SOAPY_SDR_RX, RX1, "LNAL")
self.sdr.setAntenna(SOAPY_SDR_RX, RX2, "LNAL")
# Create data buffer and start streaming samples to it
self.rx_stream = self.sdr.setupStream(SOAPY_SDR_RX, SOAPY_SDR_CS16, [RX1, RX2]) # Setup data stream
elif(self.channel[0] == 1):
self.sdr.setGainMode(SOAPY_SDR_RX, RX1, True) # Set the gain mode
self.rx_stream = self.sdr.setupStream(SOAPY_SDR_RX, SOAPY_SDR_CS16, [RX1]) # Setup data stream
elif(self.channel[0] == 2):
self.sdr.setSampleRate(SOAPY_SDR_RX, RX2, fs) # Set sample rate
self.sdr.setGainMode(SOAPY_SDR_RX, RX2, True) # Set the gain mode
self.sdr.setGain(SOAPY_SDR_RX, RX2, "PGA", 0) # programmable-gain amplifier (PGA)
self.rx_stream = self.sdr.setupStream(SOAPY_SDR_RX, SOAPY_SDR_CS16, [RX2]) # Setup data stream
else:
print("Channel amount has to be 1 or 2")
def get_signal(self): #this function reads stream of data and puts it in self.rx_stream numpy array
self.sdr.activateStream(self.rx_stream) # Initialize the receiver using Soapy. This turns the radio on
if (len(self.channel) == 2): # Read the samples from the data buffer
sr = self.sdr.readStream(self.rx_stream, [self.RX1_buff, self.RX2_buff], self.N, timeoutUs = self.timeout_us)
sr = self.sdr.readStream(self.rx_stream, [self.RX1_buff], self.N, timeoutUs = self.timeout_us)
sr = self.sdr.readStream(self.rx_stream, [self.RX2_buff], self.N, timeoutUs = self.timeout_us)
rc = sr.ret # number of samples read or the error code
assert rc == self.N, 'Error Reading Samples from Device (error code = %d)!' % rc
self.sdr.deactivateStream(self.rx_stream)# Stop streaming
self.sdr.closeStream(self.rx_stream)
def make_iq(self, filenames): #this function makes complex64 from ADC bits and saves it as binary file
RX1bits = self.RX1_buff.astype(float) / np.power(2.0, self.rx_bits-1)# Convert interleaved shorts (received signal) to numpy.complex64 normalized between [-1, 1]
RX2bits = self.RX2_buff.astype(float) / np.power(2.0, self.rx_bits-1)
RX1complex = (RX1bits[::2] + 1j*RX1bits[1::2])
RX2complex = (RX2bits[::2] + 1j*RX2bits[1::2])
RX1complex = np.insert(RX1complex, 0, (self.N + 1j*self.freq) )
RX2complex = np.insert(RX2complex, 0, (self.N + 1j*self.freq) )
RX1complex = np.complex64(RX1complex)
RX2complex = np.complex64(RX2complex)
RX1complex.tofile(filenames[0])
RX2complex.tofile(filenames[1])
RX2complex.tofile(filenames[0])
if __name__ == "__main__":
parser = argparse.ArgumentParser()
parser.add_argument("--center", type=float, nargs='?', help="Set local oscillator frequency")
parser.add_argument("--time", type=int, nargs='?', help="Set measurement time")
parser.add_argument("--samprate", type=float, nargs='?', help="Set sampling rate")
parser.add_argument("--bw", type=float, nargs='?', help="Set bandwidth")
parser.add_argument("--channel", type=int, nargs='+', help="Set channels to read data from")
parser.add_argument("--filename", type=str, action='append', nargs='+', help="Path to saved file")
args = parser.parse_args()
if args.time and args.samprate and args.bw and args.filename and args.channel:
print ("Central frequency set to ", args.center, " Hz.")
print ("Measurement time set to ", args.time, " sec.")
print ("Sampling rate set to ", args.samprate, " Samples/sec.")
print ("Bandwidth set to ", args.bw, " Hz.")
if ( len(args.channel) == len(args.filename[0]) and len(args.channel) == 1 ):
print ("Reading from channels ", args.channel[0])
print ("file saved as: ", args.filename[0][0])
#initialize Lime SDR with entered measure time, bandwidth, sampling rate
Lime = LimeSDR(args.center, args.time, args.bw, args.samprate, args.channel)
Lime.get_signal()
Lime.make_iq(args.filename[0])
elif ( len(args.channel) == len(args.filename[0]) and len(args.channel) == 2 ):
print ("Reading from channels ", args.channel[0],args.channel[1])
print ("file saved as: ", args.filename[0][0], args.filename[0][1])
Lime.get_signal()
else:
print ("channels amount not equal to amount of files")
else:
print ("No parameters were given")
Any comments or ideas would be kindly appreciated, because I have no idea what to do. The only restriction is that measurements have to be done using Python3 script.
Bests,
Skye
