Hello, I am trying to do the FM Transmitter example from https://wiki.myriadrf.org/Gr-limesdr_Plugin_for_GNURadio.
The thing is that when I plug in my LimeSDR Mini, it says that the USB COM PORT is /dev/stream-2-1.
So I edited LimeRFE Control with that port. When I try to run the program, I get the following error, any idea?
Executing: /usr/bin/python -u /home/rodrirq/top_block.py
LimeSuite Sink (TX) info
Connecting to device
LimeSuite version: 20.10.0-myriadrf2~bionic
gr-limesdr version: 2.2.7
Device list:
Nr.:0 device:LimeSDR Mini, media=USB 3.0, module=FT601, addr=24607:1027, serial=1D5898185A3503
Reference clock 40.00 MHz
Using device: LimeSDR-Mini(1D5898185A3503) GW: 1.30 FW: 6
INFO: device_handler::set_samp_rate(): set sampling rate: 2 MS/s.
INFO: device_handler::set_rf_freq(): RF frequency set [TX]: 446.094 MHz.
INFO: device_handler::set_analog_filter(): Filter calibrated. Filter order-4th, filter bandwidth set to 5 MHz.Real pole 1st order filter set to 2.5 MHz. Preemphasis filter not active
TX LPF configured
INFO: device_handler::set_digital_filter(): digital filter CH0 [TX]: 1 MHz.
INFO: device_handler::set_gain(): set gain [TX] CH0: 60 dB.
INFO: device_handler::set_antenna(): Selected TX path: Band 2
CH0 antenna set [TX]: BAND2.
LimeSuite RFE info
LimeRFE: Opening /dev/stream-2-1
init_serialport: Couldn’t get term attributes: Inappropriate ioctl for device
LimeRFE: Failed to open device, exiting
.>>>Done
