This post is more for my curiosity then a fix. My XTRX is installed and working although I am a bit confused in regard to a persistent security notice “loading out-of-tree module taints kernel” which appears whenever I power on the computer. In reference to an earlier response
I get it and I had the impression that the driver was signed when DKMS built it. The driver module was obviously not unloaded at shutdown but why the message at power up? If I remove the driver with modprobe -r limepcie and reload with modprobe limepcie, there is no such warning. Is it really signed? Here is the result of the unload-reload sequence following power up:
:~$ sudo dmesg -T | grep limepcie
[Wed Feb 19 08:33:52 2025] limepcie: loading out-of-tree module taints kernel.
[Wed Feb 19 08:33:52 2025] limepcie: module verification failed: signature and/or required key missing - t
ainting kernel
[Wed Feb 19 08:33:52 2025] limepcie : module init v0.1.9-g815fafad
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: enabling device (0000 → 0002)
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: [device info] LimeSDR-XTRX FW:4 HW:18 PROTOCOL:1 S/N:0x0
00000000E5DD8A2
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: 8.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x2 li
nk)
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: dma_get_required_mask: ffffffff.
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: try_set_dma_bitmask(32): test buffer va:000000001c27aa93
pa:1057aa000 bus:fffff000
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: using 32bit DMA mask
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: 1 MSI IRQs allocated.
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: DMA buffer size(65536)
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: DMA channels: 1
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: Creating /dev/limepcie0/trx0
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: Creating /dev/limepcie0/control0
[Wed Feb 19 08:33:52 2025] limepcie 0000:02:00.0: UART count: 0
[Wed Feb 19 08:39:36 2025] limepcie 0000:02:00.0: [Removing device] vid:10EE pid:7023
[Wed Feb 19 08:39:36 2025] limepcie : module exit
[Wed Feb 19 08:39:59 2025] limepcie : module init v0.1.9-g815fafad
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: [device info] LimeSDR-XTRX FW:4 HW:18 PROTOCOL:1 S/N:0x0
00000000E5DD8A2
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: 8.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x2 li
nk)
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: dma_get_required_mask: ffffffff.
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: try_set_dma_bitmask(32): test buffer va:00000000b1b204d9
pa:10e484000 bus:fdeef000
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: using 32bit DMA mask
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: 1 MSI IRQs allocated.
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: DMA buffer size(65536)
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: DMA channels: 1
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: Creating /dev/limepcie0/trx0
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: Creating /dev/limepcie0/control0
[Wed Feb 19 08:39:59 2025] limepcie 0000:02:00.0: UART count: 0
