Hi!
I’ve been playing around with the LimeNET Micro I just received, and it works beautifully! I plan on installing osmo-nitb next week and playing around with a GSM base station.
In the meantime, I’ve tried the GNSS receiver. By plugging an external antenna, the LED5 turned to blinking green, indicating a lock (as per Hardware Description).
The NMEA data from the uBlox GPS can be retrieved on UART1 (/dev/ttyS0). After some fiddling around, I managed to enable the interface in /boot/config.txt (thanks to this post):
force_turbo=1 enable_uart=1 dtoverlay=uart1,txd1_pin=32,rxd1_pin=33
The NMEA data can then be read by typing:
stty -F /dev/ttyS0 ispeed 9600 && cat </dev/ttyS0
However, I’m still puzzled why LED3 is still blinking Red/Green, which according to the hardware specs, indicates an unlocked PLL. Does this mean the clock is still not synced to the GPS? Do I need to configure something else?
Thanks for your help!
